1992 Oldsmobile 98 No crank
JAY GREAVES
Engine Mechanical problem
1992 Oldsmobile 98 6 cyl Front Wheel Drive Automatic
I have a no click or crank situation. I have replaced the starter and solenoid. I am good at the battery. The ignition switch powers up and goes off when engaged like it should. The starter will turn over if jumped at the solenoid. I have checked all the fuses.
Jul 19, 2010 at 7:32 PM
  • 75,988 POSTS
Your probable causes here could be one of the following the park/neutral position switch, starter enable relay and ignition switch
Jul 19, 2010 at 9:00 PM
