1991 Oldsmobile 98 R and R step by step
130,000 MILES • 6 CYL • FWD • AUTOMATIC
DDUNCO
I would like to swap a trans into my olds, picked a working trans out of the wrecker and need some help with the swap as i have never had a front drive car trans out. i do have the factory service manual but it is not all that helpful, could you fellas steer me in the right direction?
Sep 8, 2010 at 4:27 AM
  • 110,246 POSTS
Because of the work, I recommend thaking it to a sop. For me to explaine it, I would write 10 pages and stll I may miss something. I recommend getting a good repair manual.
Nov 5, 2010 at 5:17 AM
DDUNCO
I have the factory service manual, and am in the process of tearing the trans out, I have to drop the sub frame and support the engine to stabilize it front to back. The factory manual is not that helpful....thanks though.
Nov 5, 2010 at 8:19 AM
  • 110,246 POSTS
If you run into a problem or have a question, let me know.
Nov 5, 2010 at 6:33 PM
