1990 Oldsmobile 98 Starter
106,243 MILES • 6 CYL • FWD • AUTOMATIC
FOTINI
my car would not start the other day and in looking at my voltage gage I saw that it had dipped below the 13 mark, just into the red. My battery was 6 y/o and assumed I needed to change it so I did. My car will noit start, it makes no noise when turning the ignition and it is clearly not the battery. It has been suggested it may be a starter or starter solenoid perhaps even a relay. without a Chilton I am unable to locate the starter, can you help?
Oct 23, 2009 at 7:20 AM
  • 110,248 POSTS
It is located where the engine mounts to the transmission (front of car). It is about at the top of the oil pan (for height).
Apr 15, 2010 at 2:59 PM
