1990 Oldsmobile 98 Runs rich
CHARLIE1965
  • 11 POSTS
Engine Performance problem
1990 Oldsmobile 98 6 cyl Front Wheel Drive Automatic
Thank you for your time. I have a 90 Olds 98, when it's cold it runs rich at start up. The service engine, and temp light come on during the rough idle. But it has NO codes, current or history, not even while the light is on. Fuel pressure within specs (40-48), regulator checks out good. replaced module, crank sensor (was dieing), and computor.
Dec 10, 2008 at 1:34 AM
JAMES W.
  • 2,394 POSTS
A bad MAP sensor will make it run rich on cold startup. But, I would be more concerned with the ECM first. In your posting you "replaced module", which module? Please advise.
Dec 15, 2008 at 6:05 AM
CHARLIE1965
  • 11 POSTS
The module I replaced was the one under the coil pack. I have also replaced the temp. sending unit. The ECM has been replaced. Running out of options. Thank You for your responce.
Dec 15, 2008 at 7:15 AM
JAMES W.
  • 2,394 POSTS
Well, without engine codes to go by, I would have followed the same routine you have. I'm going to give you a few assumptions.
Then you start the car cold, it "chugs" until it warms up, then it runs fine. Yes?
At a cold start, if you rev it up a little, it kinda' clears up a little, but back at an idle, it chugs again. How am I diong so far?
A theory, engine temp sensor is telling the ECM the engine is cold and richens up the fuel pulse to compensate. It should also open up the idle air control valve to compensate for the richer mixture, but it's not. Have you cleaned the IAC control or checked it for operation? Please advise.
Dec 15, 2008 at 8:49 AM
CHARLIE1965
  • 11 POSTS
Thank You,
You are dead on so far. I have not checked IAC. Car does not have MAP sensor, so I guess we can rule that out. I will chech IAC. Any idea why Service engine, and temp light are on while it chug's?
Thanks again,
Charlie
Dec 15, 2008 at 12:14 PM
JAMES W.
  • 2,394 POSTS
Charlie, if you raise the rpms or after the engine warms up, do the lights go off? They both get their signal from the ECM. If they are on all the time, I would suspect a problem in the wiring between the dash panel and the ECM. Let me know.
Dec 15, 2008 at 12:36 PM
CHARLIE1965
  • 11 POSTS
Lights go out when engine runs better, like you said, when engine is cold it chug's (runs rich), and engine / temp lights are on.
Dec 16, 2008 at 12:21 AM
JAMES W.
  • 2,394 POSTS
Charlie, if the IAC valve is just "grunged up", you can clean it with a can of spray carb cleaner. This seems to work the best.
Dec 16, 2008 at 5:17 AM
CHARLIE1965
  • 11 POSTS
I took throttle body off cleaned entire throttle body and IAC. still have same problem on cold start up (chug's). Throttle body was very grunged. Sounds like it has a miss. It sounds like it's missing out the tail pipe.
Dec 19, 2008 at 3:35 AM
JAMES W.
  • 2,394 POSTS
This is a "toughy". With no engine codes, let's try to create one. Try unplugging the O2 sensor and see if the computer set a TC for an O2 problem. I think if we find out why the ECM isn't registering codes, we'll find the problem. Let me know. Also, if the motor is running as rich on startup as you say, you may have fouled a plug or 2.
Dec 20, 2008 at 7:27 AM
CHARLIE1965
  • 11 POSTS
Since we talked, I unplugged TPS, and got a code. I have also replaced plugs & wires. Still have same problem. Chug's on cold start, with Service Engine and Temp. lights on. still no codes, other than TPS (that I unplugged).Still sounds like a miss, when chugging. Runnng out of idea's. Please tell me of anything we've missed.
Thank's
Dec 22, 2008 at 2:23 AM
JAMES W.
  • 2,394 POSTS
Everything still points to the IAC. With engine cold, pull the IAC out. When you turn the key to "on", the IAC motor should pull the valve back, or to open. If not, do you have voltage to the connector and continuity through the motor?
Dec 28, 2008 at 5:57 AM
CHARLIE1965
  • 11 POSTS
I tried turning the key on with the IAC out of the throttle body. It kinda wiggled, (didn't really move). But when I turned the key off, it came all the way out. The plunger fell out into my hand. I tried a used one I had (to a different year motor), and it did the same thing. Where do we go from here???
Thanks
Dec 29, 2008 at 12:55 PM
JAMES W.
  • 2,394 POSTS
OK, when you start the cold, and while it's doing it's chugging thing, pull off a vacuum line somewhere on the intake manifold so you create a gross vacuum leak. Your checking to see if the rpms rise and the "chugging" improves. In doing this we are doing the same thing as the IAC does.
Dec 30, 2008 at 11:21 AM
CHARLIE1965
  • 11 POSTS
Yes, RPM's increase with vacume hose disconected.
Dec 30, 2008 at 1:29 PM
JAMES W.
  • 2,394 POSTS
Does the "chugging" seem to be less with the vacuum hose disconnected?
Dec 30, 2008 at 1:45 PM
CHARLIE1965
  • 11 POSTS
Yes, RPM's come up, and it runs smoother. Is the IAC working correctly? Or do we need to replace it? As I stated, it wiggles when I turn the key on, and push's plunger all the way out when I turn the key off.
Dec 31, 2008 at 1:58 AM
JAMES W.
  • 2,394 POSTS
There has to be a problem with the wiring between the ECM and the IAC unit. Do you have, or have access to a fax # and I can ship you a copy of the diagram. I can attach it to this post, but it won't come through very clear. There are 4 wires connecting to the IAC. One open circuit and one to close. Apparently yours is closing alright, but it won't open. Please advise. I wish I had a diagram for the intermnals of the ECM, but I don't.
Dec 31, 2008 at 5:08 AM
CHARLIE1965
  • 11 POSTS
Thanks,
I have access to wiring diagrams. I will check this out, and let you know what I find.
Thanks
Dec 31, 2008 at 9:34 AM
CHARLIE1965
  • 11 POSTS
Thank You for all your help. FINALLY got it fixed. Replaced crank sensor AGAIN, must have gotten a bad one. Cranked right up, and idled smooth as can be.
Thanks Again.
Jan 14, 2009 at 6:47 AM
JAMES W.
  • 2,394 POSTS
Charlie, the only thing I can think of is the CPS must have been sending a late signal to the ECM therefore, retarding the ignition timing and injector pulse. Something in my guts tells me this is going to come back to haunt us, I hope not. Glad you found it. I'll keep this one for future reference.
Jan 14, 2009 at 12:23 PM
