1990 Oldsmobile 98 motor mount replacement
195,000 MILES • 6 CYL • FWD • AUTOMATIC
FUMBLEFINGERS
  • 5 POSTS
Right side (next to firewall) motor mounts both transmission and engine front. How do I get to the 2 top bolts to remove the nuts. I am unable to feel the 2nd one or see it (transmission mount)? Pictures would be a great help.
Also where is the ALDL connector? I have an Actron III Code Scanner.
Jan 24, 2010 at 2:26 PM
BLUELIGHTNIN6
  • 16,542 POSTS
May have to remove theexhaust pipe-to-exhaust manifold bolts and separate the exhaust pipe to access the motor mount better..
https://images.2carpros.com/forum/automotive_pictures/261618_1_98.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_2_79.jpg
Diagnostic ALDL connector will be found under the left side of the dash.
Jan 24, 2010 at 2:48 PM
FUMBLEFINGERS
  • 5 POSTS
Those drawings don't look anything like my 90 Olds engine. It has 2 front mounts and 2 rear (transmission) mounts I have included pictures of those 2 mounts. I will later take a picture of what may be my Olds ALDL connector Tomorrow and send it for your identification.
https://images.2carpros.com/forum/automotive_pictures/469745_Transmission_mount_right_rear_1.jpg
https://images.2carpros.com/forum/automotive_pictures/469745_motor_mount_right_front_1.jpg
Jan 25, 2010 at 11:21 AM
BLUELIGHTNIN6
  • 16,542 POSTS
k you must have the VIN C engine style then. check this out..
https://images.2carpros.com/forum/automotive_pictures/261618_1_99.jpg
Remove the air intake duct. Remove the throttle cable and bracket from the throttle body.Raise and safely support the vehicle. Remove exhaust. Then remove the mounts.
Jan 25, 2010 at 12:24 PM
