1989 Oldsmobile 98 vibration damper
111,000 MILES • 6 CYL • FWD • AUTOMATIC
RICKMAN
I need to remove the vibration damper in order to remove the timing chain cover.
Is the damper bolt a left or right hand thread?
I assumed it was a right hand thread and have broken a wrench trying to turn it counterclockwise. Is it possible that its a left hand thread?
Any advise to remove this old rusted on bolt?
many thanks for the info
Rick
Oct 4, 2010 at 6:09 PM
DOCFIXIT
  • 18,828 POSTS
Need an impact wrench that bolt is torqued to 220 ft.lbs. and bolt is removed counter clockwise
Oct 5, 2010 at 2:48 AM
RICKMAN
Thanks DocFixit,
I was sure somebody out there could answer this for me.
I would have felt really BAD if I had been trying to turn it the wrong way.
That's 220 lb torgue plus 20 years of heat and rust.
Would it help to try and soak it with WD40 or some other penetrant? Could that stuff actually penetrate something this old?
Thanks again!
Oct 5, 2010 at 8:53 AM
DOCFIXIT
  • 18,828 POSTS
PB blaster better to use if no impact can rent electric from Home Depot. or braker bar with 4 ft cheeter pipe
Oct 6, 2010 at 7:16 AM
