1989 Oldsmobile 98 erratic engine noise at idle
1989 OLDSMOBILE 98
250,000 MILES • 6 CYL • 2WD • AUTOMATIC
ATLLOYD
have eratic knocking type noise while engine at idle,oil level is good and was recently changed,noise coming from front upper part of engine.what is most likely the cause?
May 3, 2010 at 2:54 PM
Could be valve lifters or oil pressure problem due to engine bearings and worned out oil pump.
May 11, 2010 at 3:04 AM
