1988 Oldsmobile 98 engine stays to cool
135,000 MILES • 6 CYL • FWD • AUTOMATIC
HOTWALKER1
my car will only show an engine temp when it is idling and not moving once in motion it barely reads on the gauge, and in turn in cold weather wont produce enough heat to run warm air inside the car
Jan 9, 2010 at 8:53 AM
  • 110,248 POSTS
It sounds like the thermostat is stuck open. REplace it and that should take care of the problem.
Let me know if it works for you.
Apr 15, 2010 at 2:39 PM
