1988 Oldsmobile 98 crank sensor
KIRTBURGESS
Engine Mechanical problem
1988 Oldsmobile 98 6 cyl Front Wheel Drive Automatic
I replaced the crank sensor and now the car wont start please help
Jul 22, 2010 at 8:13 PM
JDL
  • 16,098 POSTS
Did it start and run before you replaced the crank sensor?
Visually check for spark at the plugs, engine cranking. Also check for injector pulse. What is your vin?
Jul 23, 2010 at 3:06 AM
