1972 Oldsmobile 98 Engine Stalls at High Rmps
86,000 MILES • V8 • 2WD • AUTOMATIC
A72OLDS98
Hello, I have an original olds with a 455 in it. The carb idles a littel heavy at first and city driving, it seems to bog from a complete stop and stall. Let's say a crowded red light in Chicago. Also, when traveling over 40-50 mph, the engine completely stalls, and won't start up again. I don't know if this is a fuel pump issue or a carb issue or an engine issue. Please Help!
Aug 10, 2010 at 4:03 PM
  • 75,988 POSTS
Could be the carbuerator accelerator pump and power valve/main metering circuit-check the fuel pressure, coil,contact point/ECM/distributor pick-up coil
Aug 10, 2010 at 8:21 PM
