1968 Oldsmobile 98 fluid
TONY SANCHEZ
Transmission problem
1968 Oldsmobile 98 V8 Two Wheel Drive Automatic
why transmission fluid burst out of dipstick, only when i drive.??
Aug 10, 2010 at 8:42 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check the air bleed take it off and clean with carb or brake cleaner.you should check the line pressure it could have clogs.If you did a filter change it may not be installed right some have a metal
seal on the filter make sure you got it out of the hole and put on the new one
Aug 10, 2010 at 12:22 PM
