1998 Oldsmobile 88 Won't start
111,000 MILES • 6 CYL • FWD • AUTOMATIC
1998OLDS
My 1998 Olds 88 will not start. There is fuel but no spark. I do not measure any voltage to the coil with the key in the start position. The crankshaft sensor is new. I am looking for ideas.
Thank you
Oct 4, 2009 at 11:12 AM
  • 75,988 POSTS
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
Oct 4, 2009 at 11:14 AM
