1998 Oldsmobile 88 Turn Signal and Horn
1998 OLDSMOBILE 88
94,000 MILES • 6 CYL • FWD • AUTOMATIC
TERRMATHIS3
I just bought a 1998 Oldsmoblie 88/LS. The turn signal and horn don't work and the former owner told me it was a relay. Do they use the same relay,and were can I find it?
Dec 21, 2009 at 12:25 PM
JDL
  • 16,098 POSTS
Welcome to the forum, if the two problems are connected, it may be the wiring circuit in the steering column. We can check the systems one at a time. As far as your turn signals, the turn and brake lites at the rear use the same bulb filament, just not at the same time, the lower brake lites are wired through the turn signal switch. I'd have to check the turn feed to and from turn signal switch. You can check the turn fuse--20 amp, fuse block, left side of dash, that circuit goes hot when you turn on the key, use a testlite.
Dec 22, 2009 at 3:24 AM
