the oldsmobile i have keeps running hot, and i keep coolant and water in it and it still continues to run hot. could my fan need repalcing or is there something else possible affecting the car to overheat?
i also just replaced the transmission in it not too long ago and it ran alot better for a little while and then started to overheat. sometimes when i'd come back to the car it would'nt start for a little while it wouldn't even turn over....i'd let it sit for like an hour and it crank right up, but sometimes i wouldn't even do that and i had to tow it home...what do you think i should do?
Aug 4, 2009 at 4:45 AM
