1998 Oldsmobile 88 head torque specs
HAPIKAMPUR69
Engine Mechanical problem
1998 Oldsmobile 88 6 cyl Front Wheel Drive Automatic
I need to torque the heads,but my wrench is in inch pounds .what would the right amount of torque?
Jul 6, 2009 at 6:29 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Step 1 37 Ft. Lbs. (50 Nm)
Step 2 Additional 120 Degrees
Step 3 (4 center bolts) Additional 30 Degrees
37 Ft. Lbs. is = to 444 INCH Lbs. Will be easier for you to just borrow / rent a different torque wrench..
Jul 6, 2009 at 7:28 AM
