1998 Oldsmobile 88 Can't See
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
T0PPER
My Oldsmobile 88 won't kick out any air. The A/C and the heat won't turn on as well as the defrost (front and rear). All of my fuses are in tact. Is it the blower motor or is it something more?
Oct 26, 2009 at 12:43 PM
JDL
  • 16,098 POSTS
welcome to the forum. I'd check the circuits at the blower relay, center rear of engine compartment, maybe on the firewall. If you can see the wiring colors, orange- red- dark blue- black- purple. Dark blue wire is voltage for lower speeds, goes hot with key on and hvac controls. Red wire is voltage for high speed, hot all the time. No continuity for high speed unless relay is energized. When relay isn't energized, continuity for lower speeds.
Oct 27, 2009 at 7:14 AM
