Bleed brakes
1998 OLDSMOBILE 88
DANSTER
Brakes problem
1998 Oldsmobile 88 6 cyl Front Wheel Drive Automatic
RIGHT WAY TO BLEED ALL 4 W/ ABS
May 18, 2009 at 5:49 AM
DOCFIXIT
  • 18,828 POSTS
Hi
If ABS module or master cylinder not replaced or opened. Then it is Right rear, Left rear then right front, left front. Pump @4-5 times hold crack bleeder, close repeat.
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
An ABS scan tool will be necessary to get air out as you hold each valve open to get the air out.
https://youtu.be/rTtAnsOlZU4
This shows the scan the operation is similar.
May 18, 2009 at 6:42 AM
