1997 Oldsmobile 88 Slips out of " Overdrive"
1997 OLDSMOBILE 88
175,000 MILES • 6 CYL • FWD • AUTOMATIC
RATCHET9978
I'm having transmission problems on a 1997 Oldsmobile Delta 88 with 175000 miles, after 4+ hours of driving via Interstate. Every so often my transmission will slip out of gear (OD) and redlines, this will occur 2-3 within a 1000 miles. Each time I must downshift and sometimes I can only travel at speeds between 50-60 mph. After 10 mins. of babysitting, all is back to normal and it might not happen again for another 300-600 miles. Someone suggested this could be the engine and transmission failing to communicate via an electronic sensor? I've googled several different words and have had no luck, any suggestions?
Jan 29, 2009 at 4:48 AM
BILLYMAC
  • 2,204 POSTS
hi not likely this could be eng related.or computer related. if the ecm or any sensor was going to cause anything it would cause the trans to shift into a diff gear or even not shift at all. comeing out of gear and going into neutral can only be caused by the releaseing of the overdrive band or clutches.i would have the car scanned for trans codes.but this really sounds interenal to me thanks billymac
Jan 29, 2009 at 5:02 AM
RATCHET9978
Very helpful Billymac, thank you.
Jan 29, 2009 at 11:52 PM
