I'm having transmission problems on a 1997 Oldsmobile Delta 88 with 175000 miles, after 4+ hours of driving via Interstate. Every so often my transmission will slip out of gear (OD) and redlines, this will occur 2-3 within a 1000 miles. Each time I must downshift and sometimes I can only travel at speeds between 50-60 mph. After 10 mins. of babysitting, all is back to normal and it might not happen again for another 300-600 miles. Someone suggested this could be the engine and transmission failing to communicate via an electronic sensor? I've googled several different words and have had no luck, any suggestions?
Jan 29, 2009 at 4:48 AM
