1986 Oldsmobile 88 Transmission
1986 OLDSMOBILE 88
EWILKINS
Transmission problem
1986 Oldsmobile 88 6 cyl Four Wheel Drive Automatic
What is it when the car is not pulling and is smoking but when you put transmission fluid in it it works and pulls
Jul 12, 2010 at 5:19 AM
  • 110,244 POSTS
Is there a trans leak? It sounds like ATF is leaking on to the exhaust, smoking, and the level in the trans is too low until you add to it.
Let me know if you can see any leaks.
Aug 13, 2010 at 2:31 PM
