1997 Oldsmobile 88 please help
1997 OLDSMOBILE 88
DAMIEN.JONES25
Shakes or Wobbles problem
1997 Oldsmobile 88 Automatic
my car suddenly just bogs down when you try to give it gas, and it starts to shake, what could be the problem?
Mar 11, 2010 at 1:24 AM
LEGITIMATE007
  • 5,121 POSTS
check the idle air control valve and clean the throttle body, you should be good to go after that, by the way, is there a check engine light on? and you may want to do a fuel filter too, for good measure and that will eliminated that
Mar 11, 2010 at 6:00 AM
