DASH AIR VENTS
DMCGEE
  • 5 POSTS
Interior problem 6 cyl Front Wheel Drive Automatic 74000 miles
no air from any dash vent only floor and defroster. have replaced ac programmer module and all levers move. the flow will change according to diff. button pushed but not dash vents. i have move the door lever by hand and it moves freely. why no dash vent air flow? where do i go from here? thanks
Jul 10, 2009 at 12:31 AM
MERLIN2021
  • 17,250 POSTS
Have you checked the vacuum supply line? If broken, the system defualt to defrost.
Jul 10, 2009 at 12:48 AM
DMCGEE
  • 5 POSTS
before i replaced the ac program module i checked the vacuum and it pulled good. also the vacuum inside the module is good. and it makes the control arms move. is it possible that the blend door is broken inside the unit? if so will i have to take out the whole dash to get into the box? thanks
Jul 10, 2009 at 12:53 AM
MERLIN2021
  • 17,250 POSTS
Here's the diagram of your system, it could be one of the mode doors stuck, or the actuato could be NG if you have a vauum tester/pump, apply vacuum to them and see if the lever on them move, if the hold vacuum, maybe a diaphram on it is bad...
https://images.2carpros.com/forum/automotive_pictures/62217_88a_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_88b_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_88c_1.jpg
Jul 10, 2009 at 2:47 AM
DMCGEE
  • 5 POSTS
THANKS, for the info...!!! I have a lot of work ahead of me. I will let you know what i find....
Jul 10, 2009 at 2:49 AM
MERLIN2021
  • 17,250 POSTS
I'll be checking on you!
Jul 10, 2009 at 2:51 AM
TSBARKER13
This sounds like what I need to check, but how to I gain acces to the vacuum hoses behind the control to check and replace? (1999 Olds 88)
Aug 8, 2017 at 6:06 AM
  • 55,456 POSTS
These cars had a big problem with the blend door actuator. Here is a guide to help you (below)
You can get them on Amazon.
https://www.amazon.com/gp/product/B004SF0Y4K/ref=as_li_qf_sp_asin_il_tl?ie=UTF8&tag=2carprcom-20&camp=1789&creative=9325&linkCode=as2&creativeASIN=B004SF0Y4K&linkId=4c34365bea3e2c974fbd8faf0f061e7a
Here is a guide to help you get the problem fixed.
Cheers, Ken
Aug 12, 2017 at 10:58 AM
