1997 Oldsmobile 88 car starts
1997 OLDSMOBILE 88
78,000 MILES • 6 CYL • FWD • AUTOMATIC
WODIESON1
when car starts windows work while the car is on i play with the window switch and it cuts off... check all fuses still puzzled... can u help me
Jun 30, 2009 at 6:57 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
WHat you need to do is when it doesn't work, you need to remove the door panel and check if the motor is getting power. IF it is, the motor is the problem. If there is no power, chances are the switch is the problem.
Jul 6, 2009 at 11:42 PM
