1997 Oldsmobile 88
DEANGELA22
Transmission problem
1997 Oldsmobile 88
My car will go into every gear but reverse. When I put it in reverse it just kind of growls when I give it gas. But when I put it into drive it will go forward and not make that sound.
Jan 26, 2009 at 1:33 AM
RHALL77
  • 3,361 POSTS
sounds like the reverse clutch is out and needs to be replaced. call your local trans shop to see if they can help you with it. most likely it will have to be removed
Jan 30, 2009 at 2:14 AM
