1996 Oldsmobile 88 Starter won't engauge
1996 OLDSMOBILE 88
100,000 MILES • 6 CYL • FWD • AUTOMATIC
CRDUDE44
i have a 96 olds 88 it won't turn over I tried jumping the solenoid and it will turn over then and start for a min then die So it seems the starter and solenoid are ok but no luck as faras usng the key
It was running and starting fine the other day we went to the store came out and it wouldn't turn over
Jun 27, 2009 at 4:32 AM
JDL
  • 16,098 POSTS
Hello, maybe your theft system is causing a problem? Have you tried wiping off the pellet in the key, try a different key.
Jun 27, 2009 at 5:26 AM
CRDUDE44
I tried wiping the key and i tried a different key neither worked,is there a way to bypass or reset the system
Jun 29, 2009 at 7:02 AM
JDL
  • 16,098 POSTS
Have you tried cranking it in neutral? First, you need to be sure the problem is the theft system?
Jun 29, 2009 at 8:05 AM
CRDUDE44
yes i tried starting it in neutral
Jun 29, 2009 at 1:24 PM
