when the car is cold after sitting for 3 hrs or more. It starts, runs, then the volts and heat lights come on and the car dies. I can keep the car running by giving it gas, It puts a lot of gas and smoke out the exhaust. the speedometer needle also moves when the volts light comes on. The problem first started if I had the cruise control on when I started the car, if I turned it off the car would run fine. If I turn the cruise on going down the road it starts running bad. the car runs fine after it gets warm.
Dec 7, 2009 at 3:34 AM
