1995 Oldsmobile 88 pass key 2 codes
123,000 MILES • 6 CYL • FWD • AUTOMATIC
BIGGONE27
i bought this olds for nearly nothing from a fellow tech, he was given the car by a wealthy couple to fix and give a needy family. he soon found out he didn't want to put any more money in it with the economy like it is.so i think ,i'll give his parts money back and my wife can drive it.
it was giving cam sensor and crank sensor codes ,so i change both, and i notice water pump was leaking onto the crank sensor. i think, i got it i put all ac delco parts.the same problem i change pcm ,it runs good but the light comes on i scan it, pass key 2 codes, security system codes that were not there before, it still ran 2 days then no start i cleared it,and left key on ten minuitesto reset the security system i guess factory then it ran agian . WHAT DO I DO NOW?????? please help me before i burn this very nice car.
Jun 16, 2009 at 12:44 PM
BMRFIXIT
  • 19,053 POSTS
Check this post
https://www.2carpros.com/forum/1990-cadillac-deville--ignition-problems-vt160134.html
also you can buy resisters and by pass the system
good luck
let me know
Jun 16, 2009 at 1:08 PM
