1995 Oldsmobile 88 CAR STALLS or CUTS OUT
GEOARCH9
  • 1995 OLDSMOBILE 88
  • 6 CYL
  • 122,000 MILES
Car stalls while driving, and when slowing for a stopsign. Will run well sometimes for about 45 minutes then cuts out. When driving from point to point, will sometimes not start after sitting parked for a short period.
Saturday, August 14th, 2010 AT 3:01 PM
  • 110,176 POSTS
Has the check engine light come on? Have you checked fuel pump pressure?
Saturday, August 14th, 2010 AT 11:03 PM
GEOARCH9
The answer is yes to both. The light has come on, the pump works and delivers fuel to the injectors. Fuel flow looks strolng, but I do not have a pressure gage.
Sunday, August 15th, 2010 AT 1:52 PM
  • 110,176 POSTS
First, I need you to have the computer scanned. If the check engine light is on, there should be a diagnostic code stored in the computer. Most parts stores will do it for free. Let me know what you find. If I feel it isn't related to the issue, I will need you to check fuel pump pressure. It may seem to have enough pressure, but may be low.
Sunday, August 15th, 2010 AT 9:58 PM
GEOARCH9
Thsnks, I will do that and let you know the results.
Sunday, August 15th, 2010 AT 11:38 PM
  • 110,176 POSTS
Thanks. The check engine light / scan should point us in the right direction. Make sure to get the diagnostic code for me.
Monday, August 16th, 2010 AT 10:46 PM
