Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Oldsmobile
88
Engine
Symptoms
Overheat
1995 Oldsmobile 88
1995 OLDSMOBILE 88
169,500 MILES • 6 CYL • FWD • AUTOMATIC
TANYA ROBEY
MEMBER
1 POST
what would make a car over heat if there is coolant in it a new thermostat
Nov 4, 2008 at 11:26 AM
LEGITIMATE007
Experienced Mechanic
you can check your engine coolant temperature sensor, if that is not the problem then you may need to replace your radiator because it may be plugged
Nov 4, 2008 at 12:12 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
