1994 Oldsmobile 88 What is wrong?????????????
53,000 MILES • 6 CYL • 2WD • AUTOMATIC
LISALCLARK3
We have changed the spark plugs, changed the oil. oil filter, air filter, fuel filter, egr valve, and cleaned the maf. I t was running really well yesterday. Like it should. This afternoon it is running like it is about to die and check engine light is on. I took it to a garage to see they hooked it up and it wouldn't register any code. what can it be now please help!!!!!!!!!
Aug 12, 2009 at 12:43 PM
  • 75,988 POSTS
Clean out the idle air control valve and test the TPS and MAP sensors-
Aug 12, 2009 at 10:59 PM
