1994 Oldsmobile 88 Pulley turning intermittently
120,000 MILES • 6 CYL • FWD • AUTOMATIC
ELTABOR
  • 13 POSTS
The pulley on my compressor turns intermittently all the time the engine is running, with or without A/C on. Shouldn't the pulley turn freely to keep from wearing out the belt? if so what is my problem?
Thank You
Ed
Mar 27, 2010 at 11:14 AM
  • 110,244 POSTS
Ed:
The ac compressor runs in cycles. When this happens, does it appear as if the belt is slipping, does make noise...? Also, does the AC work when you turn it on?
Apr 14, 2010 at 5:45 AM
ELTABOR
  • 13 POSTS
[quote:98d3644109="Jacobandnickolas"]Ed:
The ac compressor runs in cycles. When this happens, does it appear as if the belt is slipping, does make noise...? Also, does the AC work when you turn it on?[/quote:98d3644109]yes to all three
Apr 14, 2010 at 10:11 AM
  • 110,244 POSTS
It sounds like one of two things. Either the belt is loose due to a weak tensionier, or the compressor is locking up. Have the tensionier tested first.
Let me know what you find.
Apr 14, 2010 at 3:03 PM
