1994 Oldsmobile 88 Oil Pressure Warning Light
1994 OLDSMOBILE 88
JFROELICHER
Electrical problem
1994 Oldsmobile 88 6 cyl Front Wheel Drive Automatic
I need to check to make sure that the oil pressure warning sensor has not disconnected. Where can I find it on the engine?
Jan 19, 2010 at 5:20 AM
  • 110,240 POSTS
It's on the passenger side, (lower engine area), above the oil filter. It's mounted in the engine block.
Let me know if you find it.
Apr 15, 2010 at 3:22 AM
