1994 Oldsmobile 88 no fuel pressure
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
DSBRDLY92
The car would die while driving it, so I replaced the fuel filter, then the fuel pump. Now it has no pep, I have replaced the coil, and i still have no pressure. What should I do next?
Feb 27, 2009 at 4:39 AM
JDL
  • 16,098 POSTS
I saw what you replaced, did you do any testing? Use a gage, check fuel pressure. Are there any codes? Your obd 1, you should be able to check codes yourself?
https://images.2carpros.com/forum/automotive_pictures/170934_aldl_8.jpg
Use a jumper between the A & B terminals, turn the key on till the dash lites come on, no crank, the mil starts flashing, you count the flashes to get the codes.
Feb 27, 2009 at 5:05 AM
