Hi David,
Thank you for the donation.
Intermittent problems are always a nightmare to mechanics.
From the symptom decriptions, I believe the cause is a power supply interruption and we should concentrate on this first.
If the Check Engine Light is indicating, get a scan done to retrieve for trouble codes so we can proceed from there.
If no codes are found, get the alternator tested.
Saturday, June 19th, 2010 AT 4:04 PM
