1994 Oldsmobile 88
GAILTILLIS
Transmission problem
1994 Oldsmobile 88 6 cyl Four Wheel Drive Automatic
transmission fluid leaks out and the car wont move forward how much is this going to cost to fix
Oct 31, 2008 at 1:02 PM
IMPALASS
  • 3,112 POSTS
Hello –
Not knowing where it is leaking out may be a simple fix. It may not be moving forward because it is low on transmission fluid. Make sure you check that. For a replacement it can range from $1500-$2000.
Oct 31, 2008 at 4:48 PM
