1993 Oldsmobile 88 rough start up
1993 OLDSMOBILE 88
87,000 MILES • 6 CYL • FWD • AUTOMATIC
CPU999-1
rough start up and no power when going then problem gos away .I tune it up change plugs that's all I did then the problem started after that
Feb 20, 2010 at 4:14 AM
JDL
  • 16,098 POSTS
Hi, what all did you do on the tune-up? Changing plugs is a small part of a tune-up. Did you get the plug wires back in the correct location? Are there any trouble codes? Use a gage and check fuel pressure.
Feb 20, 2010 at 5:12 AM
CPU999-1
after I change the plugs the car ran just fine n/p so plug wires in rite spot dont have a code finder to pull codes and no Gage for f/p but the problem gos away after driving it
Feb 20, 2010 at 7:48 AM
JDL
  • 16,098 POSTS
You don't need anything special to check codes, your obd1. To check mil codes, you can place a jumper wire between A & B terminals of datalink connector. Then turn the key just till the dash lites come on, no further. The mil starts flashing, you count the flashes to get the codes. Your looking for two digit codes.
Also, some of the national brand autostores used to loan out a fuel pressure gage. You can call and ask.
If the problem is temp related, check the coolant temp sensor.
Feb 21, 2010 at 1:52 AM
