1993 Oldsmobile 88 car won't turn over
1993 OLDSMOBILE 88
14,000 MILES • 6 CYL • FWD • AUTOMATIC
PJDUCK
checked all the fuses in both panels and under the hood, checked the battery and the connections, switched the starter, checked the key. Car started fine last time I drove it. I can jump it at the starter but it won't stay running. Have no idea what to check next. Thank you for your time
May 18, 2010 at 3:04 PM
Clean out the idle air control valve and test the throttle position and manifold absolute pressure sensors.
May 18, 2010 at 5:38 PM
