1993 Oldsmobile 88 broken rod
120,150 MILES • 6 CYL • 2WD • AUTOMATIC
HAVOC_CHAOS
I Just bought a '93 Oldsmobile 88R, but it has a few problems. I know that it has a bad power steering pump. But there is also a rod on the bottom of the car by the right front tire. When you turn the car to the right you hear a knocking sound. Could you please tell me what that rod is called.
Nov 20, 2008 at 2:57 PM
PEAR69
  • 1,482 POSTS
If both wheels steer when you turn the steering wheel then the rod is the stalizer bar. If bith wheels do not turn then it is a tie rod.
Nov 20, 2008 at 3:11 PM
