HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Oldsmobile
88
Engine
Throttle Body
Clean
1993 Oldsmobile 88
NATESGPA
MEMBER
1993 OLDSMOBILE 88
Engine Mechanical problem
1993 Oldsmobile 88 6 cyl Front Wheel Drive Automatic
RELACED INTAKE PLENUM AND CLEANED THROTTLE BODY NOW MOTOR RACES AND BLOWS SMOKE OUT TAILPIPE
Saturday, June 6th, 2009 AT 6:09 PM
OBXAUTOMEDIC
MECHANIC
The racing of engine is most likely a vacuum leak.
What color smoke?
Saturday, June 6th, 2009 AT 7:15 PM
Please
login
or
register
to post a reply.
Related Throttle Body Clean Content
Vacuum Line Diagrams
Successfully Replaced Spark Plugs And Pcv Valve But In The Process Broke A Hard Plastic Line. It Comes From A Box Right Next To The Maxi-...
Asked by
BettyBadA
5 IMAGES
1995
OLDSMOBILE 88
1996 Oldsmobile 88 96 Olds Engine Swap, Passkey...
Computer Problem 1996 Oldsmobile 88 6 Cyl Front Wheel Drive Automatic 100k + Miles Hey Guys. Here Is The Story. The '96 Olds 88 Had...
Asked by
Bunta
1996
OLDSMOBILE 88
1996 Oldsmobile 88 Harmonic Balancer Puller
Engine Mechanical Problem 1996 Oldsmobile 88 6 Cyl Two Wheel Drive Automatic The Harmonic Balancer Does Not Have Tapped Holes For The...
Asked by
jashurst
1996
OLDSMOBILE 88
1999 Oldsmobile 88 Oil Pump Not Pumping Oil
Is There A Diagram Available To See Where The Oil Pump Is Located -- Is It Internal/external. Is This A Difficult Job? Car: 1999...
Asked by
naplsgal
1 ANSWER
1999
OLDSMOBILE 88
1998 Oldsmobile 88 Engine Rebuild
Hi, I Want To Swap My Engine From 98 Olds 88 Into A 99 Pont Bonneville. Both Cars Have The 3.8l Series 2 Engine. I Think These Engines...
Asked by
HammondD
1 ANSWER
1998
OLDSMOBILE 88
VIEW MORE
Service Throttle Body Toyota Highlander V6
Throttle Body Service
Throttle Service Toyota Tundra 2000-2006
