1992 Oldsmobile 88 starting
PNICK
  • 1992 OLDSMOBILE 88
1992 Oldsmobile 88 6 cyl 140000 miles
just had ignition module, coils and complete tuneup, battery replaced two months ago but still does not start right. The more I drive the harder it is to start, cranks slow needs a shot of accelerator to start could the battery be bad? Or do I need a starter?
Saturday, July 25th, 2009 AT 7:28 AM
HMAC300
  • 48,601 POSTS
You first need to charge the battery and go to an auto parts store and have it checked. Then pull the starter and do the same. Auto parts stores can do this. That should cure teh cranking problem, after that have a pro put a scanner on it to see if there areany codes causing you problems ignitiion wise.
Wednesday, November 11th, 2009 AT 7:23 PM
