1992 Oldsmobile 88 ignition module
132,000 MILES • 6 CYL • FWD • AUTOMATIC
M.D.GRIFFIN
after up to normal temp., you turn eng. off,It
will not restart until module has cooled about
30 minutes.(no fire) I have changed modules,
module plug, coil pack,etc.whats causing the
module to heat up???????(I've tried 2 used
modules and 2 new ones.same result.)
Nov 12, 2008 at 2:20 AM
MASTERTECHTIM
  • 4,750 POSTS
problem is not the module but the crankshaft position sensor. seen it a thousand times
Nov 12, 2008 at 2:41 AM
