1992 Oldsmobile 88 heater core
1992 OLDSMOBILE 88
GETSOME
Heater problem
1992 Oldsmobile 88 6 cyl Front Wheel Drive
how to replace the heater core on a 88 olds royal, can't find the bolts to remove the dash board, i already have repair manual, but it does not give detail on ho to remove the dash board, can't find the bolts underneath the dash board.
Oct 30, 2009 at 8:00 PM
BLUELIGHTNIN6
  • CAR REPAIR CONTRIBUTOR
  • 16,542 POSTS
REMOVAL:
Properly disable the SIR system.
Drain the cooling system into a suitable container.
Using a suitable pair of hose clamp pliers, unfasten the clamps, then disconnect the heater hoses from the heater core.
If equipped with manual climate control, remove the A/C temperature valve actuator as follows:
A.Remove the instrument panel assembly.
B.Remove the temperature valve link rod from the temperature valve by snapping it out.
C.Detach the electrical connector from the A/C temperature valve actuator.
D.Unfasten the retaining screws, then remove the A/C temperature valve actuator.
If equipped with electronic climate control, remove the programmer as outlined in the following steps.
A.Open the glove compartment, disengage the stops and swing the door down.
B.Detach the electrical and vacuum connectors.
C.Remove the driver temperature valve link rod.
D.Unfasten the screws and remove the programmer from the vehicle.
Remove the heater core cover screws, then remove the cover.
Unfasten the heater core retainers, then remove the heater core assembly.
Oct 30, 2009 at 8:08 PM
GETSOME
do i have to remove or take out the entire dash board
Oct 30, 2009 at 8:19 PM
BLUELIGHTNIN6
  • 16,542 POSTS
no, the dash does not have to be removed. only what was stated above.
Oct 30, 2009 at 8:27 PM
GETSOME
Thank you, will try to fix it tomorrow
Oct 30, 2009 at 9:47 PM
