1992 Oldsmobile 88 Harmonic Balancer
1992 OLDSMOBILE 88
TK32
Engine Mechanical problem
1992 Oldsmobile 88 6 cyl Front Wheel Drive Automatic
I'm having a problem removing the balancer,the manual I have says nothing about a puller.Looking at the balancer it does not look like you could attach a puller to it anyway.Well my question is has anyone removed one of these before and do you need a special type of puller?Thanks tk32
Oct 17, 2008 at 11:21 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:d850122240="tk32"]Engine Mechanical problem
I'm having a problem removing the balancer,the manual I have says nothing about a puller.Looking at the balancer it does not look like you could attach a puller to it anyway.Well my question is has anyone removed one of these before and do you need a special type of puller?Thanks tk32[/quote:d850122240]
It is difficult to get off especially if it has never been off. You can use a pry bar and carefully pry one side a little then the other, once it starts moving you should be able to use your hands to finish removing it.
Oct 17, 2008 at 11:27 AM
