1992 Oldsmobile 88
1992 OLDSMOBILE 88
20,688 MILES • 6 CYL • FWD • AUTOMATIC
CHAVOURS
I hear noises in the left tire area when ever I turn to the left. Breaks were done, and noise continues. Breaks were completely gone on left side but not right side. I hit a huge pot hole on the express and the car as been running noisy since. It sounds like something is scrubbing or loose. The rim was bent and it was replaced. Like I said the breaks were done also....can you at least tell me if I get the alignment on the car would this help the problem. Also is this going to cost me more than what the car is worth now? Oh you can only hear the noise when you are driving, you can't hear it if you are on the outside of the car.
Feb 9, 2010 at 4:44 AM
JAYBIN82
  • 44 POSTS
does it "clunk" when you put it in gear? a alignment is fairly cheap. if you do decide to get it dont, just tell them what its doing, more then likley they will check it out for free and tell you what it is when they do the aligment. im thinking it might be a cv joint.
Feb 9, 2010 at 4:55 AM
