1992 Oldsmobile 88
1992 OLDSMOBILE 88
JASHTON
Shakes or Wobbles problem
1992 Oldsmobile 88
My car has been shaking very badly the faster I drive. It's noticeable, but barely, below about 40 mph.. above that it shakes so badly I can't see out the rear view mirror.
Apr 28, 2010 at 4:30 PM
VEGASFARMKID
  • 30 POSTS
Check your tires, if possible lift the vehicle and rotate each tire by hand.Look for a "bubble" or "lump" on the outside circumference due to radial belt separation. Do the front first.
Apr 28, 2010 at 4:51 PM
JASHTON
If this is the problem, what is the solution? New tire? I don't know if I have a jack, but I will inspect my tires by hand all-around. Thank you!
Apr 28, 2010 at 6:08 PM
