1991 Oldsmobile 88 starting
1991 OLDSMOBILE 88
14,000 MILES • 4 CYL • FWD • AUTOMATIC
NATALIE1978
I pulled in a parking lot turned car off and went in to storer. came right back out tried to crank the car and it would crank. It didnt make any noise. just one little click sound. Is it the starter?
Feb 8, 2010 at 3:35 AM
No crank at all/nothing/nada:
Could be the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
Feb 8, 2010 at 10:49 AM
