1991 Oldsmobile 88
1991 OLDSMOBILE 88
155,000 MILES • 6 CYL • 2WD • AUTOMATIC
ARTUR
When I come to a stop sign and stop, and then take off again the car sits there and revs and then eventually goes into gear. Then it shifts fine through all the other gears. Also if I shift into neautral at the stop sign then back to drive it takes right off. Is the transmission shot or is it something else?
Jan 22, 2010 at 11:58 AM
  • 110,244 POSTS
Are you sure it isn't low on fluid?
Apr 15, 2010 at 3:18 AM
