1990 Oldsmobile 88 Speedometer short
1990 OLDSMOBILE 88
150,000 MILES • 6 CYL • FWD • AUTOMATIC
LAZARUS4
Recently has an 80K engine put in. Since then I've had intermittent operation of the speedometer while driving. I replaced the VSS since I was also replacing Cam and Crank sensors as well.
My speedometer still fluctuates randomly.
Where should I next check? I'm guessing somewhere in the harness...
Dec 18, 2009 at 2:21 AM
  • 110,244 POSTS
If you replaces the VSS, chances are the cluster itself is the problem. It was common for them to short.
Dec 18, 2009 at 5:28 AM
LAZARUS4
Thanks for the insight. My logic is:
The speedo only started acting up after the new engine got put in. When it works is acts like a very touch wire connection (which of course could be the cluster) What I was sort of hoping to do was get a harnass diagram check to make sure that all the connections are solid, before I start pulling out the dash.
So, Does the feed to the Speedo come from the computer directly? Is there a connection that I can check to ensure proper installation?
tks
Dec 18, 2009 at 6:50 AM
  • 110,244 POSTS
I have a copy of the schematic, but you will need to enlarge it to read it. Here is what you are looking for. From the VSS, there are two wires, a purple one and a yellow one. Both go to the ECM numbers B9 and B10. From the ECM, number B11, a signal is sent to the speedo through a dark green wire. A red wire, B12, is for the cruise control. Here is the schematic. I hope it helps.
https://images.2carpros.com/forum/automotive_pictures/249084_vss_2.jpg
I hope it helps and you can enlarge it. Looking at it as a map, go to B-5.5. Let me know if it helps or if you have other questions and thanks for using 2carpros.com. Joe
Dec 18, 2009 at 3:22 PM
