1990 Oldsmobile 88 engine
DEEDEE35
  • 11 POSTS
Engine Performance problem
1990 Oldsmobile 88 6 cyl Front Wheel Drive Automatic
could my problems i'm having come from the voltage regulator thats making the car cut off when hit gas not getting enough amps
May 18, 2010 at 12:29 AM
  • 31,937 POSTS
Hi there,
No, i would be looking at something like a throttle position sensor, a scan will give you a good indication as to where the problem is, check for any unresolved fault codes first.
mark (mhpautos)
May 18, 2010 at 12:32 AM
