1989 Oldsmobile 88 turn signals & brake lights
86,000 MILES • 6 CYL • FWD • AUTOMATIC
1989OLDS88
I recently took my car into a repair shop to have it serviced for the brake lights not working and the turn signal not working. They replaced the fuse (20v). It worked for a day. The next day it started working but 5 minutes into driving it stopped working again. It was 5 degrees outside (don't know if this matters or not). Is it the fuse? Is it the relay? Or is it a more complicated electrical issue? Thanks
Jan 28, 2010 at 2:27 AM
  • 110,248 POSTS
If the fuse blew once, chances are it is bad again. Check it. If it is blown, then you have a short. Start at the rear lights and make sure the sockets are good and wiring isn't damaged.
Let me know what you find.
Apr 15, 2010 at 3:12 AM
